Sunroof motor
My 2004 freelander sunroof motor is very sluggish. But works fine to tip the glass, but very sluggish when moving the whole glass back. I'm afraid it wont return.
1. Is the problem likely the motor, or is there something else that might be resisting?
2. If the motor, where can I get one?
3. Does anyone have instructions for replacing the motor? Need to take off the headline?
Thanks.
Thanks.
there is a manual way to close it, however this is only useful when it is unable to close itself, ie the motor doesnt work. if the motor is functional but it wont close, its because its jammed, and you will not be able to override it without breaking it. use it very sparingly until its fixed.
The sunroof on my 2004 Discovery stopped working. First pounded it because in the South, it sometimes get hot and sticks. Didn't work this time. Removed panel and hooked back roof switch to front but didn't work. That left either ECU or motor. I picked the motor because the back sunroof worked and I don't use the back as much as the front. Called dealer -- wanted $495 for new motor! Went online found a '99 Discovery motor for $49. Plugged it in -- it worked. Beat the dealership system again.
davidlafrance
12-20-2010 07:22 PM
