Freelander Talk about the Land Rover Freelander within.
Synthetic Oil or not?
Old Mar 3, 2007 | 03:15 PM
02FreeLander's Avatar
Default Synthetic Oil or not?
My main question is, im thinking about buying a 02 freelander one owner older guy
Says hs never used Synthetic oil in his rover, but every manual i read says to use synthetic oil only?
just want to know if others dont use synthetic oil also
Old Mar 5, 2007 | 02:49 PM
05LandRover's Avatar
Default RE: Synthetic Oil or not?
sorry, i'm running mobil 1
Old May 11, 2007 | 12:31 PM
Pied's Avatar
Use Synthetic oil. And Mobil 1 is awesome stuff.
Old May 11, 2007 | 12:46 PM
Or Castrol or Amsoil, they are all great, also use a good quality oil filter like a Mobil 1 or a K&N.
Mike
Old May 28, 2007 | 10:15 PM
RDM3's Avatar
8th Gear
Check your manual, it states very specific weight and brands. I went with the Mobil 1 option.
Old Jun 7, 2007 | 02:58 PM
maloucarr's Avatar
I've always used synthetic oil on mine, and the manufacturer are actually very adamant about using synthetic oil.
Old Jun 8, 2007 | 01:37 AM
wease206's Avatar
i use fully synthetic mobilone 10/30oil filter k&n or mobil one
Old Jun 13, 2007 | 03:06 PM
anthonyp's Avatar
Hello,
The biggest danger of not using the synthetic oil is the build up of sluge in the engine. I would definately have a good macanic look it over. If it has alot of sluge buildup ask his opion on a safe way to remove it before switching to the correct synthetic old. Depending on the miles, switching over to synthetic after she has used regular oil for a long time could stop up the oil filter with the slug (Very, Very, Bag Thing).
Hope this helps,
Anthony
Old Jul 18, 2007 | 02:45 PM
happyhippo's Avatar
3rd Gear
I've always used Mobile1 0-40 as the book recommends in mine but I asked mybrother who is a 30 year mechanic when I first bought it and his opinion was sure it's better butit doesn't really matter as long as it's changed at 3k intervals. I stuck with the synthetic throughout the warranty period just so there could be no issue with that. I'm not sure if I'll change to standard oil now or not but at $4-$5 a quart synthetic gets expensive. [&:]
Old Dec 30, 2008 | 02:21 PM
riptide33's Avatar
4th Gear
I'm also running the 0 - W40 in mine and have 146,000 miles on it. I'm having a few minor issues but other than that she's still going strong.
david426
Jun 21, 2013 05:09 PM
mcgyver210
Jun 7, 2010 10:16 PM
muddybuddy
Jun 4, 2009 08:50 AM
herblatham
May 1, 2008 05:57 PM
GCS1
Aug 9, 2007 07:26 AM
