"transfer neutral"
Introduction
OK....Hi! My name is Steve and I am a Land Rover owner....(this is the 12 step help program, right?)
Now to the issue, I had inadvertantly put a fuse in position 11 in the fuse box. When I started the truck and seen "Transfer Neutral" on the dispaly I relaized what I had done. Turned off truck, removed fuse and now it will not go back into High. I have run through the shifter to try to get it into either Low or High but no luck. Basically I am stuck in Tow mode.
If anybody has any ideas as to what to look for or do to get it back into gear I would be greatly appreciative.
Thanx in Advance
Steve
Thanx in Advance
Steve
OK...I climbed under the truck, found the Tcase motor and ended up switching it in High myslef by putting 12v to one of the post. I am still getting the "transfer neutral" error but I can at least move it in case I decide to stick it out back by the old studabaker.
I am assuming that there is some sort of Control Unit for the 4wd system and I am guessing that maybe it just doesn't know that the truck is in Low or High which would tell me that Shifter Selector may be on the fritz.
Please feel free to chime in with any suggestions from you gurus out there.
RoverLover
13
05-11-2016 08:55 AM
RoverLover
03-02-2006 05:01 PM
