02 Range Rover Heater Core Issue?!!??!?!?
Old May 31, 2007 | 06:37 PM
tgrife's Avatar
5th Gear
Default 02 Range Rover Heater Core Issue?!!??!?!?
Hey fellas and ladies. I just took my 02 Range Rover in to the dealer to look at a coolant/antifreeze leak that was coming from under the passenger side running board and also a bit coming into the passenger front floor board. I figured that it was the heater core leaking and possibly the O Rings. They diagnosed the issue as the O Rings being fine and just the heater core needing to be replaced. They estimated the cost at $2413.00. I was wondering what you guys feel about this and if this estimate is fair. Any feedback would be greatly appreiciated.
Thanks,
Tim@1010productions.com
Old Jun 7, 2007 | 05:18 PM
motoguzzi's Avatar
6th Gear
Default RE: 02 Range Rover Heater Core Issue?!!??!?!?
While I cannot speak for the newer models, I have a '90 County and '91 Hunter and both needed heater cores. This is a very common problem on the Classics. My Pop changed them both so they were cheap to me. If you live in Southern CA and know that these are the same (I am not sure) I could see what my Pop would charge (the whole dash has to come out in order to get the heater core/fan blower/adjustment box out of the car.
Old Jun 8, 2007 | 01:24 AM
wease206's Avatar
Hi I have a the same problem on my RR 98 it is very easy fix. The Heater Cord O-Ring cost about 8.00 and you need 2 of them you will also need a senor is about 30.00. All you have to do is removed the glove box and the side pandle heat vent. you job take about four hour to complete make sure you drain your coolant or esle it will srip all over the front floor broad.
here is a site for you it have evrything you need to know and what you need to fix it
http://www.rangerovers.net/repairdet...ateroring.html
Old Jun 8, 2007 | 09:07 AM
Tim, you had better call around and see if you can get a better price from a shop that has done this sort of repair before. It won't be cheap cause it is a hard job to do, basicily the whole dash will be coming out.
Mike
Old Jun 9, 2007 | 02:22 AM
wease206's Avatar
Tim only if RHD the dash comes out but if you have LHD then you dont i just did this job two days ago you can call me and i will help velaa206@msn.com your number
Old Jun 9, 2007 | 02:40 AM
wease206's Avatar
yes mike is right you have to take the dash out only RHD.
But if you have LHD this is what you do removed the glove box
to removed the glove box reomoved cover under the glove boxit has3 screws after cover removed fourscrews will loose the glove box then open the glove box
removed 5 screws then glove removed after that removed center windows switch console 2 screws
then the gear concole 1screws after that left side pandle just 2 screws after that removed the vent then you will see the heater o-ring you will need a snake tool for this also a new screws cause the old one that hold the heater o-ring it get damage i hope this help you
Old Jun 9, 2007 | 02:42 AM
wease206's Avatar
i can email you a picture
Old Jun 9, 2007 | 08:26 AM
I stand corrected.
Mike
Old Jun 9, 2007 | 06:50 PM
wease206's Avatar
i stand on my correction information too.
Old Jun 10, 2007 | 02:41 AM
wease206's Avatar
the only time if the dash have to come apart if you have to change the heater it self but this job is just the heater 0-ring.
no disrsepect to you mike you you the best when it come to land rover information.you know we talk about other stuff and i know you are smarter than in land rover stuff hat down your the guy
