04' Range Rover?
04' Range Rover?
Hey everyone, I am new to this site so bear with me. I have always liked Range Rovers and last year I had the opportunity to purchase a pretty clean 04' Range with only 47,000 miles. Since my purchase, I have had the steering angle ECU, CD changer and stereo/navigation head unit changed. The steering ECU caused the vehicle's rt side to sag lower than the left when operating at normal ride height so the dealership changed it and the stereo's cassette player did not operate when I purchased the vehicle as well as the CD changer but I found those problems after the purchase. Besides this, the car works well.
My concern I want to pose to everyone is that my vehicle is in the shop currently for the radiator leaking fluid from a top seam and will need replacing along with the valve cover gaskets leaking oil. I only have 53,000 miles on the car and I need a new radiator and valve cover gaskets? This is suppose to be a higher/end vehicle correct? So whay am Ihaving these problems early. Comments... Thanks....
Rovers are high maitenance. Just cause its high end doesn't mean its not going to have its share of... quirks and stupid garbage that breaks. I would imagine these repairs are not cheap especially being at a dealership. You might want to consider taking it to a local Rover shop and have them give you a second opinion before the dealership rapes you. Your valve cover gasket leak could have been repaired by just tightening the bolts on the covers. This vehicle might have been off road a lot considering the kind of things needing to be replaced.
You inherited all the problems that would have been caught while under warrantee. Although a steering wheel sensor wont cause the vehicle to sit funny. A height sensor will.
It will get expensive, best bet to minimize some major issues is to change the oil more often. Cut it down to 7k instead of 15k. Your pcv system will thank you for it.
Thanks for the response.
Lincoln Tarantino
11-14-2011 10:41 PM
Skimino Farms
07-30-2011 07:47 AM
wilson96rr
01-03-2009 10:44 AM
nextelsucks
Appearance & Camping Set Ups
05-18-2008 08:58 PM
nextelsucks
03-28-2008 09:25 PM
