06 RR lowering overnight
Old Aug 19, 2008 | 01:27 PM
wmb's Avatar
wmb
4wd High
Default 06 RR lowering overnight
Hello my truck is lowering to entry level overnight. It immediately raises in the morning to normal height when started. Are the bags leaking? One bag? I am under warrantee but just wondering what could be doing this onceit is movingall is well.
2006 HSE w/40K
Thanks for any assistance!
Old Aug 19, 2008 | 07:24 PM
roverguy7's Avatar
Default RE: 06 RR lowering overnight
only thing ive seen leak on an 06 is the fitting at the reservoir, but this wouldnt cause it to drop, are you parking on a level surface?
Old Aug 19, 2008 | 10:24 PM
wmb's Avatar
wmb
4wd High
it is possible that where the truck was parked that there was a slight angle left to right... would this cause a drop? Acting perfectly otherwise and no fault warnings.
thanks again!
Old Aug 20, 2008 | 08:55 PM
roverguy7's Avatar
it can, as weight is shifted, ie more on pass side in your case, itll sit lower on that side, and the system will level it out as time goes by, it will only lower in order to level it, park it on a flat surface, make sure expecially that one wheel is not in a hole or anything like that, see what happens, if nothing, dont worry about it, if it does it again, take it into the dealership
JohnRL
Jun 26, 2012 10:08 PM
faversham
Jun 11, 2012 05:40 PM
frw2012
Jan 7, 2012 11:31 AM
VegasBD
Nov 1, 2009 09:37 AM
RamblingMan
Jan 22, 2009 07:14 PM
