12' Supercharged RRS engine knock/rattle
So I pulled the supercharger belt and started the car and the rattle was gone however there was a ticking sound but maybe that was just the supercharger moving from the intake air moving through it. Will it be okay to drive until we can get a replacement part? I found this on eBay http://www.ebay.com/itm/Rebuilt-Rang...53.m1438.l2649
Here's a video of the noise with the belt removed.
https://youtu.be/gCdAbkV5eD8
I think he is referring to the oil cooler pipe LR028136
Remember you need the Oring too. You can see the bits here> Water Pump Kit: Fits The LR4, Range Rover Full Size And Sport
no, that is the oil cooler tube that goes into the BACK of the water pump. I'm talking about the small 1/4" fitting that goes into the front. It's some sort of one way check valve. Looks like it's one of those parts that's been replaced by another part that's been replaced.
Can it be replaced with the supercharger still on the vehicle? This one is offered on eBay. http://www.ebay.com/itm/Rebuilt-Rang...53.m1438.l2649
WYRover (10-18-2017)
You will need to remove it, but it isn't the end of the world to get it apart. Plus you will be sure to get a good seal. Re: the rebuilt part from ebay, IDK anything about the seller/company.... IMHO I'd go OE. A rebuilt "anything" is only as good as the core that was used. For what it's worth, I don't buy any rebuilt parts. Maybe someone here who has used a rebuilt snout can give you more info. Good Luck!
WYRover
06-20-2017 04:58 PM
huladaddy
01-15-2017 11:51 AM
RNG-RVR-18
08-25-2012 04:04 PM
