1993 RRC cat-exhaust over heat
Old Feb 12, 2011 | 01:18 PM
idahorover's Avatar
Default 1993 RRC cat-exhaust over heat
1993 4.2L the passenger side catalytic converter "i think that's what it is" gets glowing red and the exhaust seems like it get excessively hot within a mile or two of driving. Then it starts to back fire and the check engine light will come on after about 2-3 miles of driving. The overheat light or radiator light doesn't come on. When you stop and let it idle the RPM's go down and up it back fires a little and tries to stay running but then it will die. (It does the same thing if you let it just idle for awhile). It will start right back up. . Could it be the O2 sensor because I notice it will blow a fuse sometimes under the seat that has something to do with the O2 sensor.
Old Feb 12, 2011 | 01:19 PM
LRScott's Avatar
The catalytic converter is clogged.
Old Feb 12, 2011 | 01:20 PM
idahorover's Avatar
How do you unclog it?
Old Feb 12, 2011 | 01:27 PM
LRScott's Avatar
With a plunger of course! lol
Sorry, my bad. Its not clogged. The engine is not burning off all its fuel. The excess fuel makes it way into the converter and burns in there, causing it to glow red. Defective O2 sensors can cause this problem, but usually it is related to improper ignition. Could be fouled plugs and wires and maybe even a bad ignition coil pack.
Old Feb 12, 2011 | 01:39 PM
idahorover's Avatar
I'm glad I don't have to use my new plunger I have relatives coming to town that eat to much fiber. Thanks
WNYErikDiscoII
Nov 7, 2013 09:32 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
howido213
Oct 26, 2011 10:06 AM
elboy0712
Dec 19, 2010 02:48 PM
cold_surfer
Feb 5, 2008 07:04 AM
