1997 Range Rover still shaking
Old Dec 8, 2013 | 09:40 PM
Bassmaster's Avatar
Default 1997 Range Rover still shaking
My 1997 range rover has been shaking and wobbling. I changed the drag link and track bar and all the ends. The wobbling has stopped but the car still shakes around 45 mph but once I get passed 50 it completely stops.
Any ideas what could cause this?
Old Dec 8, 2013 | 10:05 PM
Fivespddisco's Avatar
Tires, Bad drive shaft are my 2 guesses
Old Dec 9, 2013 | 04:11 PM
Bassmaster's Avatar
I did put newer rims on it. They are bigger then the old ones
Old Dec 9, 2013 | 09:07 PM
Rims are not centered
Old Dec 10, 2013 | 05:32 PM
Bassmaster's Avatar
Should I get them balanced? Or just new rims and tires?
Old Dec 11, 2013 | 06:46 AM
drowssap's Avatar
it a lot cheaper to have the balance check than replacing tires and rims, plus if they are in balance think of the money you will have waisted on tires and rims.
Old Dec 11, 2013 | 05:23 PM
Bassmaster's Avatar
Alright I'll get that done and let you all know what happens
Old Dec 11, 2013 | 05:26 PM
jafir's Avatar
Pics of the rims? You might need hub centric rings.
Old Dec 11, 2013 | 08:10 PM
Bassmaster's Avatar
It's the 2004 range rover rims
Old Dec 11, 2013 | 08:15 PM
jafir's Avatar
Then it's what the lucky8 guy said. Your wheels aren't centered because the L322 RR hubs were bigger. You need little adapters that fit into the bigger bore of your new wheels so that they are the same size as the old wheels. Something like this: http://www.lawheel.com/store/accesso...-set-of-4.html But that seems expensive.
