200 4.0 EAS Fuse #29 keeps blowing ?
Old Jan 20, 2009 | 09:12 PM
rayrap's Avatar
3rd Gear
Default 200 4.0 EAS Fuse #29 keeps blowing ?
Hello,
I am new to the forum but a longtime owner of this blessed 2000 4.0 with 116Kmiles. The bags are new and until the last big frost the EAS was perfect.
With the car at full height,the pump will NOT run , the4 led lights on the interior level control switch are on, and the "35 MPH Max" warning is on the dash.I found that fuse #29 was blown and continues to blow even with the EASRelay un plugged. Any ideas gentleman ?
(Also would you believe I am buying another RR4.6 1999 tomorrow with 10,000 miles just for more abuse !!!...cheaper than a girlfirend (I'm married) and it keeps me out of the bars !)
Cheers
Old Jan 24, 2009 | 11:21 AM
skyguy's Avatar
Default RE: 200 4.0 EAS Fuse #29 keeps blowing ?
That sounds like the compressor. check one of my previous post to see how to test the compressor. When mine went out we pulled it apart and found a stuck valve.
Old Jan 24, 2009 | 07:09 PM
rayrap's Avatar
3rd Gear
Thanks dude...I will give it a try and let you how I make out.
Regards,
Ray
Old Dec 19, 2010 | 02:45 PM
stedalton's Avatar
Regards,
Ray
hi my name ste ihave the same fuse blowing fuse 29 can you please tell me how you sorted the eas fault thanks ste dalton 2000 p38 dse
Old Dec 19, 2010 | 04:27 PM
handsome rob's Avatar
I have never dealt with this one but if it is the compressor then you can at least try to unplug the compressor and replace the fuse and see what happens. The Rave manual will also help you trace down where things are connected to.
fullybuilt2.0
Freelander
Nov 20, 2011 03:50 PM
boris_gti
Oct 29, 2011 12:39 PM
mattrickman
Jul 21, 2011 05:33 PM
bosshogt
Feb 11, 2011 03:28 PM
sfxgamer
Apr 19, 2009 01:06 AM
