2001 HSE running a little hot
Old Sep 19, 2009 | 05:15 PM
cardinal77's Avatar
Question 2001 HSE running a little hot
My rover runs pretty darn hot after even short trips. I don't get any temp warnings temp gauge looks good. The engine feels very hot to me though. When I remove the oil cap I get a little smoke too. Fluid levels are perfect, oil antifreeze ect....
Other than that it runs good. leakey valve covers and oil leakage but overall not bad.
Andrew
Old Sep 20, 2009 | 01:55 PM
ldivine's Avatar
Oil does evaporate... unless our gauges are reading hot, you're getting a lot of smoke, or have any other reason to believe it is running hot, I wouldn't worry.
Old Sep 21, 2009 | 10:06 AM
cardinal77's Avatar
Thank You, just my OCD kicking in...I'm very **** with this truck..lol
Old Sep 22, 2009 | 12:33 AM
LRScott's Avatar
I tend to be very particular about my rover too. A little odd noise might cause me to panic . If you are curious as to whether your gauge is lying to you, hook up an OBD scanner to it. Temps should be anywhere from 190 to 220F. This is how I found out my rover wasn't actually over heating like the gauge said lol.
Get used to the leaks! Mine leaks, not a ton, but enough to make you go WTH when you look at the concrete in the garage.
Old Sep 23, 2009 | 12:09 PM
cardinal77's Avatar
Thank You , Good Idea
Pik
Mar 27, 2013 08:00 PM
94svt50
Jul 8, 2012 03:31 PM
fastrx7man
Jun 21, 2012 10:31 AM
LRScott
13
Apr 7, 2010 02:26 AM
twmj1953
Sep 29, 2009 09:49 PM
