2002 Range Rover HSE 4.6 for 4000
Old Oct 1, 2009 | 01:30 PM
NiveK1970's Avatar
Default 2002 Range Rover HSE 4.6 for 4000
I picked her up 2 weeks ago, the suspension is completly shot, all 4 air bags leaking, air pump is toast as well, but I picked up a coilover kit from strutmasters for 500 bux to remedy that, ya i know i would rather have the air bag system but that would cost a ton more than i have, and that may not even be the only problem with it as it's run by computers. Only other thing wrong is someone stole the nav unit from the back, the radio has no sound and the climate control display is not showing anything, the light is on, but when you press on the screen, you can make out the settings, so not sure what is up with that but all in all it has 95k miles, seemengly in decent shape for the money
Old Oct 2, 2009 | 02:55 AM
LRScott's Avatar
Well, 4k is a very good deal despite the flaws. The radio will most likely need to be repaired or replaced. The airbags on these are not cheap, but that is what makes a rover unique to any other vehicle out there. The ride is absolutely plush with air suspension, so it might be worth resurrecting. The nav unit will need the dvd drive in the back to operate and you may need to replace the climate control ECU depending on what is exactly wrong.
i_m_jon
Oct 1, 2014 01:43 PM
Brad Luca Ciociola
Jan 27, 2012 08:49 PM
howido213
Jul 29, 2011 10:27 AM
hotty
Mar 12, 2008 07:38 PM
JimMayor007
Dec 5, 2007 08:46 AM
