Is 2007 range rover sport worth buying?
Old Apr 16, 2013 | 08:45 PM
Ricosuave204's Avatar
Default Is 2007 range rover sport worth buying?
So guys a little bit of insight on this one would be much appreciated . The vehicle is supercharged with 83757 kms on it and got emtertainment system . Does is break alot at this kms or is it still worth the buy? Thanks again
Old Apr 17, 2013 | 08:26 AM
roverguy7's Avatar
It's a good truck. 06 was the first year, and had a few issues, but 07 was pretty solid. Two main issues are EAS compressor, which can now be replaced with a far superior unit, and front suspension wear. With it being supercharged, you also have the Active Roll Control system, which is fantastic, but not without issues. Make sure the fluid level is correct, no leaks, its the bottle under the hood that looks like the power steering bottle, but on the other side, and almost tucked under the radiator support. Make sure you drive it, and see if there are clunks and bangs from the suspension.
Other then that, its just basic maintenance really, which if you stay on top of, the truck will last a good long time, and be fun to drive for most of it.
SirWilliam
Apr 24, 2011 04:19 AM
danrover
Mar 25, 2011 11:12 AM
CBK
Mar 20, 2011 11:07 AM
laser_doc
Feb 12, 2008 10:11 PM
ioweyoumoney
Sights N Sounds
Jan 5, 2008 02:57 PM
