4 WD / Diff lock? RRC - need confirmation
Old Nov 17, 2016 | 01:35 PM
carl johansson's Avatar
Default 4 WD / Diff lock? RRC - need confirmation
Hey guys,
I'm currently trying to trouble shoot an issue in a 93 RCC LWB, essentially it is "locked" into granny gear.
So I just recognized I wasn't clear on exactly how that unit functions.
It's permanent 4wd correct? and then when you get in trouble - you kick it into 4 low (granny gear) right? so that lever activates the center differential lock? so that eesentially locks between front and back? and then there is a rear diff lock as well? and that "locks_ the 2 rear wheels?
so does 4 low lock the rear differential? or does the rear diff automatically lock and unlock based on wheel sensors etc?
and if going to granny gear locks it up - is that mechanical? hydraulic? electronic - how does the message get to the rear diff, and how is it activated?
thanks
Last edited by carl johansson; Nov 17, 2016 at 01:40 PM. Reason: cant spel worth shhittt
Old Nov 18, 2016 | 09:16 AM
Robert Booth's Avatar
If you have a stock '93 RRC then it does not have a manual center dif lock like on the Discovery. (Lt230)
The RRC came factory with the Borg Warner transfer case. It is a permanent 4wd solution but the BW employs a viscous coupling as opposed to a manual lock. When wheel slip occurs, the BW "locks up" (except its not a true lock)
this system performs particularly well in slippery conditions on road.
All the hi/low Range lever does is change the gearing of the vehicle.
Old Nov 18, 2016 | 03:35 PM
OK, thanks Robert, that helped alot,
Can I ask you one more question?
the high low range gear selector - where does the gear change occur? in the transfer case? I can't believe it would be the rear differential, so it has to be in the transfer case? and if so - electronic switches? cable activated? what exactly is doing the switching between the high and low options?
Old Nov 19, 2016 | 05:44 AM
It switches gear sets in the transfer case through mechanical means.
cornbreadj
Dec 27, 2014 07:50 PM
humroot
Mar 20, 2011 03:32 PM
RockinRooster
LR4
Feb 3, 2011 12:45 AM
RedAustinIX
Dec 12, 2010 10:08 AM
