91 RangeRover Classic ABS is broken but no fault codes are showing up
I need some help. I have so far been through every wire in my abs system with a multimeter, taken the abs pump apart to make sure everything was still functioning, and replaced the accumulator. I have also flushed and bled the entire brake system twice.
The problem started about 3 months ago. The abs system started coming on during normal stopping at any speed and pulsing until I slow to less than 15 mph. There are no fault codes in the abs computer ( I tried the blink method of checking it), and there are no warning lights on. I went through the manual and checked resistances at the abs ECU, and at the master cylinder for everything. Everything checked out well within the specifications described in the manual.
At this point I am at a complete loss of what to do. The only thing I can think of at this point is that the ECU itself is faulty.
Any suggestions would be greatly appreciated.
kbarker27
10-13-2023 04:03 PM
philander
08-19-2011 04:20 PM
bocamar
02-26-2011 08:47 AM
landyrangie
12-26-2005 10:20 AM
