93 range rover lwb
Old Apr 21, 2007 | 01:17 PM
thekingmaker's Avatar
Default 93 range rover lwb
can anyone help with the wipers! they just dont work. all the fuses are good. the washers work on the winsheald but not the wipers. what should i check first?
Old Apr 21, 2007 | 09:09 PM
Default RE: 93 range rover lwb
I would look at the wiper motor first, is it getting power when activated by the switch? No power, then it could be a bad switch, power without working it has to be the wiper motor.
Mike
Old Apr 21, 2007 | 10:15 PM
thanks mike. thats the way im working at just now. its a struggle getting all the bits off around the steering colume. somone that last did that put back in the wrong screws. once i can get at the switch i can test to see if the power is getting to the motor. if iut is i guess i have to take out the whole instrement cluster to get to the motor. or is there an other way? and the blower only blows the fuse on high speed. do you know anything about that? your help is really appreciated.
brian
Old Apr 25, 2007 | 11:03 PM
lightfootboyd's Avatar
4wd High
You have to replace the wiper motor. And if the blower is taling out the fuse you most likely have a dead ground short. Check the wires to the blower and the main feed under the hood
Old Apr 28, 2007 | 01:54 AM
94LWB's Avatar
7th Gear
Just a thought ... could you have a bad resister pack (speed control unit) it's under the front cowl (air intake) behind those black grills passenger side. It might be overheating (they get really funky over time) and causing that problem as well.
Joe
[align=left] [/align]
Old Apr 28, 2007 | 09:47 AM
thanks joe, i got the cowl off and saw the ballast resister you talk off. its very rusty. i was thinking that might have somthing to do with it. i just bought this rr in st paul. minasota. and drove it back to texas. i guess all those years in the snow and ice with lots of salt have had an efect on it.
brian
Danrover82
Sep 16, 2012 07:17 PM
harrellee
Jun 9, 2011 05:29 AM
keri
Oct 30, 2007 01:10 PM
rene
Feb 10, 2005 08:38 PM
deb
Nov 5, 2004 02:23 PM
