95 LWB Blower motor?
HiIn the middle of a fine snowstorn here in Massachusetts, I hopped in my 95 LWB to find that I had no heat. The problem is the blower is not working at all. I suspect I need a new blower motor, but as I have a list of other issues I have to deal with on the truck (radiator, head gaskets, etc), I am hoping this is not the case. I tried to determine if it could be a fuse, but I had no luck. Does anyone have any tips on this one? Many thanks.[/align]
I'd check the blower motor switch before pulling apart the dash to get to the blower motor. Are you checking the incoming voltage at the fuse and switch? Are you sure you're checking the right fuse in the RH footwell?
This might help...
Blower Motor
This might help...
Blower Motor
