97 p38 message center problems..............
Old Feb 17, 2011 | 11:54 AM
coleman1's Avatar
Default 97 p38 message center problems..............
I have a 97 p38 and have had plenty of problems over the years but this last one just has me beat, The truck has been in my garage for two months now, My problem is when i cut the truck off the message center says fuse 6 fuse 7 fuse 17 airbag fault gearbox fault all in a row and even after i take the key out the message center stays lit up. What could be going on with this? I have to disconnect the battery to keep it from going dead.
Old Feb 17, 2011 | 04:43 PM
LRScott's Avatar
I'm assuming you've taken a look at the condition or replaced the fuses it is whining about. You will need to dig deeper into the rabbit hole that is your electrical system. This sticky from another forum has helped a lot of people out: http://rangerovers.net/forum/viewtopic.php?f=3&t=39296. I would put it on our forums here if I had the ability. If you do not notice any improvements after trying some of the methods discussed in the sticky, it could be your BECM going out I'm afraid. Let us know what happens and good luck!
peter r
Dec 30, 2022 08:08 AM
Clementine
Aug 9, 2011 11:56 AM
coleman1
Feb 17, 2011 12:04 PM
Chadillac
May 8, 2010 06:12 AM
faversham
Nov 5, 2009 10:19 AM
