99' Range Rover HSE Starting Issues...
Old Dec 15, 2009 | 02:37 PM
Jordanmd88's Avatar
Default 99' Range Rover HSE Starting Issues...
Our P38 the other day decided it didn't want to start.. SO I tried resetting the security system with the 1515 Code.. It did nothing.. I tried swapping in a known good battery..
I swapped the starter today because, I couldn't think of anything else...
still would not turn over..
I manually jumped the starter relay under the hood, and the solenoid activated..
Any Ideas?
I think the stupid security stuff is still getting in the way.. What should I do... are there any known hard resets?
Jordan
Old Dec 15, 2009 | 07:18 PM
LRScott's Avatar
If it was the security it would be telling you in the center display, and would say "alarm fault" "engine disabled" or "push remote or use code" etc, Is it the GEMS or Bosch model? Do you hear any audible clicks? Have you checked the starter for operation? Checked fuses relays etc.?
Old Dec 15, 2009 | 07:44 PM
handsome rob's Avatar
Well since you jumped the starter relay and it worked then it could be the relay. It could also be a bunch of other things causing it. When you turn the key does it just not do anything? Does the door lights come on, what else is it doing?
Old Dec 15, 2009 | 08:53 PM
Jordanmd88's Avatar
I hear a Relay clicking near the BCM.. and One in the fuse box under the hood...
As of right now the Car has a Brand new starter.. I jumped it @ the relay and the starter is engaging.
This Rover is a GEMS model...
Yea I thought about the Relay 1st Grabbed on from one of the other Rovers, didn't help...
when i turn the key it does everything normal.. Fuel pump kicks, Accumulator pump turns on for a few sec.. Everything is normal..
Yes the door lights come on, everything works but the stupid Clarion radio, which hasn't worked for a month now..
Thanks for the support guys... I'm welcome to all ideas...
Old Dec 15, 2009 | 09:33 PM
wilson96rr's Avatar
I would check if when you turn the key to start do you get 12v at the relay? Do you have a good ground at the relay socket? One other test is to turn on the headlights, and then turn the key to start. The lights should turn off. If not, I would suspect the ignition switch.
Old Dec 16, 2009 | 11:08 AM
Jordanmd88's Avatar
Thanks for the thoughts, I am pretty sure they turn off, because the HVAC and radio turn off when I try and start the car... But I will check when I get home...
Thanks again
Lets keep the Ideas going guys
Old Dec 16, 2009 | 09:05 PM
Obviously the starter is not getting the signal to spin, I would get a manual and start tracing the hiring harness and check all connections.
I was thinking about maybe the neitral safety switch switch or something stopping it but if you can remove the key then that should not be it. With that thought, have you tried to start it in nuetral?
Old Dec 16, 2009 | 10:28 PM
Jordanmd88's Avatar
Yea... All the connections have been checked.. ect...
Tried the Neutral start 2 days ago..
The relay is getting 12v, but isn't getting the signal.. I checked the Signal wire right off the BCM... It's not getting any current At all.. And the wire going from the ignition to the BCM is working...
So my BCM is ****ed...
This is a very interesting problem.. My fuel pump is still kicking on and the starter/fuel pump are on the same circuit inside the BCM...
The connectors going into the BCM are good to go.. I am going to Open the Computer up tomorrow and look for burnt traces or pads.. or burnt/leaking capacitors ect..
If that doesn't work I'm sending my BCM off for a 500 repair...
Thanks for all the help guys..
Old Dec 17, 2009 | 12:40 AM
LRScott's Avatar
Yuck! At least they last just a bit longer than a laptop....Cost about as much too
Old Dec 17, 2009 | 05:45 AM
wilson96rr's Avatar
Just because the BECM is not sending the signal to the relay doesn't necessarily mean that the BECM is shot. The BECM could be missing a signal from some other sensor which is telling it not to send the + to the relay. That would be my guess. I think a lot of BECMs get replaced even though there is nothing wrong with them. Just something to think about. If you pull up the electrical section on Rave, you can see what each wire going into the BECM is supposed to do.
