abs doesnt run
Old Jun 23, 2009 | 06:55 PM
bobco's Avatar
Default abs doesnt run
Hi, can anyone tell me how to test my abs pump, its not running. I've been having to push on the brakes hard lately, i now know my accumulator was probably bad now i have no brakes. How do i check the pressure switch to see if its not that before i buy another pump.
I havent seen any leaking brake fluid and the tank is full. thanks bob
Old Jun 23, 2009 | 11:26 PM
mlshelton's Avatar
Start with the relay in the engine compartment fuse panel first. If the pump isn't running, it's typically a power issue, or burnt out. Might have even lost it's ground. Pressure switch may or may not be good, but without power to the pump it doesn't matter, nor can you really tell.
Mike
Old Jun 24, 2009 | 10:11 AM
Better yet, start with what year and model and what you have checked or done so far. Do you have an ABS light on?
Old Jun 24, 2009 | 11:16 AM
bobco's Avatar
sorry bout that,02' rr hse. k things done. with the engine off pumped the brakes like 25 times then i had someone turn on the engine and apply brakes i had the stethescope to abs pump and it never turned on. just checked the fuse panel 5 amp is good. Is the pressure switch located adjacent to the pump. thanks bob
Old Jun 25, 2009 | 04:59 PM
bobco's Avatar
i think shes a gonner, the pump i mean, i took of the airfilter cover for better access to the pump and got the eletrical connector for the pump apart and hooked up my multimeter as soon as the the key was turned i got 10.5 + volts continuously until i shut the motor off. I guess i need a new pump. bob
Old Jun 25, 2009 | 05:18 PM
It would be good to know what year and model you were talking about?????????????
Old Jun 25, 2009 | 05:54 PM
bobco's Avatar
Sorry, I thought the second post had it. its an 2002' range rover hse.
Old Jun 25, 2009 | 08:49 PM
LRScott's Avatar
You may want to consider rebuilding it, if it is just the motor. I've read that sometimes the metal brushes inside just wear out and need replacing. It is worth a shot since a new pump is a little over a grand.
m3dragon
Feb 24, 2015 10:08 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
hatanhi
Dec 25, 2006 11:24 AM
battsup
Jul 16, 2005 09:23 PM
ashby1
Mar 7, 2005 12:38 PM
