ABS pump noise/bleeding
Old Feb 16, 2007 | 09:25 PM
mdvickst's Avatar
7th Gear
Default ABS pump noise/bleeding
I just installed a new ABS pump and relays. The accumulator was replced before that because i originally thought that was the problem. Now the pump stays on and makes a weird noise. It gets louder at times then gets softer. It sounds like there is air inside. How do i bleed the abs pump and or the master cylinder. I bled the brake on the wheels but im ont sure if i did them correctly. Should I just keep bleeding the brakes untill the noise stops? Any help would be appreciated.
-Mark
Old Apr 30, 2007 | 08:01 PM
dallasrr's Avatar
4th Gear
Default RE: ABS pump noise/bleeding
did you ever find the solution to this?
im having the same problem.
TIA
Old Apr 30, 2007 | 11:20 PM
mdvickst's Avatar
7th Gear
yea it just needed a good bleeding. make sure you do it by the book. I followed the repair manual step by step and now it stops on a dime. Good luck.
OffroadFrance
Jun 16, 2021 04:39 AM
OffroadFrance
Feb 1, 2015 03:12 PM
Madlands
Apr 27, 2014 11:27 PM
04duxlr
Jan 8, 2014 04:22 PM
earlyrover
Oct 3, 2013 04:16 PM
