Air Suspension
Old Sep 25, 2006 | 02:57 PM
akartis's Avatar
Default Air Suspension
Can anyone tell me what are the tell tail signs of a coil conversion from the air suspension other than the obvious?
Old Sep 25, 2006 | 03:19 PM
geoman's Avatar
Default RE: Air Suspension
What do you mean by "the tell tale signs". Are you asking what symptoms of air suspension problems exist before one might want to consider a coil conversion?
Read my tech info pages at the site that refer to suspension
Regards,
Geoman
www.eurotekapg.com
Old Sep 25, 2006 | 05:21 PM
akartis's Avatar
I was wondering if it is possible to complete the coil conversion with out removing the bladders. I do not know alot about these things. As I am sure you can tell. I looked at the vehicle and see springs but I just want to make sure. The reason I am questioning is I am getting the EAS Manual on the message center and numerous chimes when starting the vehicle. Any assistance would be appreciated.
Old Sep 25, 2006 | 05:27 PM
geoman's Avatar
If your vehicle has coil springs on each corner, then someone has already done a conversion. The Air Springs go away as part of the task (the springs and adaptor plates go in their place). If you do have coils, and the warning light/chime is happening it is because someone did the conversion without disabling the EAS monitoring circuits. Some kits have a plug-in module that accomplishes this.
Regards,
geoman
www.eurotekapg.com
Old Sep 25, 2006 | 05:44 PM
akartis's Avatar
Thank you for the help. I just want to be on the safe side. I believe I may have found an EAS Override Module for sale. If I am understanding correctly this should take care of it.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
tripz
Jan 4, 2007 05:58 PM
