Air Suspension
Old Mar 12, 2005 | 03:19 PM
neilbaud's Avatar
Default Air Suspension
Hi all, I'm new to this forum, I have a 96 Range Rover I have taken to a local shop to have the break pads replace, after the pads were replaced, I've noticed an issue with the air suspension, it refuses to go up, actually the rear goes up, but the Front still remains down. I've heard of issues that only a qualify mechanic should do brake on the Range over, if any of you have experience such dilema after a break job and know how to fix it, please share your input. Thanks, Neil
Old Mar 12, 2005 | 05:29 PM
pvalianatos's Avatar
Default RE: Air Suspension
First, take it back and tell them they made more issues than they fixed. If they are reputable, then they should help you out.
Since it is an AIR suspension, you can think about the scenarios:
either are not getting air to the bags or power to the compressor or the compressor is damaged or there is a massive leak. Since it seems like it has heppened directly afetr service, it doesn't seem like it is a wearing down issue. Maybe they unplugged/disconnected something to get to the brakes?
Good luck. Let us know how it goes.
PeteV
Old Mar 17, 2005 | 11:16 AM
joerover's Avatar
First you need to have a qualified shop work on this truck. To diagnose the air suspension system you must have a Testbook or Autologic tool. Which only dealers and Some independant shops invest in. Without this tool you are playing a costly guessing game. Thanks, Rusty Owens-HR Motorcars-Rover specialists-410850-8555
Old Mar 17, 2005 | 03:59 PM
Lighting90's Avatar
Most likely they have either disconnect something or worse, they have cut or torn one fo the bags...
It is this type of failure that is seeing so many people over here in the UK changing the air bag system back to a coil sprung system..
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
tripz
Jan 4, 2007 05:58 PM
