Air Suspension Question
My 93 RR LWB looks like she's resting on top of the tires. One day the air suspension fault lights came on solid and she seemed locked in the regular ride hight, so I drove her home from work. Next morning, she was all the way down and wouldn't raise up. Completely undrivable...I took it around the block and it waslike driving on a trampoline. My manual says the air suspension fuse is 4B in the dashboard box. The fuse is fine. Any ideas? Is it time to gostraight toa coil spring replacement or worth having a dealer inspect first? It's been a good 106K Miles on the air suspension. No problems before this.
Ian
Ian
You need to have a good Rover tech, check the system, could be something simple. Don't make the suspension conversion untill all else is tried, it will never ride as nice once you go to coils.
Hi:
Look the new page for air suspension problems...
Version in english is in construction...
http://www.opcionesavanzadas.com
greetings
see.....feel....it´s Land Rover
greetings
Thank-you Mike. I have the dealer here in Phoenix as well as a reputable independent who works on Land Rovers. I'll run it past them before jumping into the coil conversion.
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
tripz
Jan 4, 2007 05:58 PM
