air suspesnion
Old Jan 3, 2009 | 08:36 AM
roverfun's Avatar
8th Gear
Default air suspesnion
happy holiday all. i have a 2000 RR county that has let me down again! i was on my was to dallas from Calfornia2hours out! and the suspension drops to the bump stops and the warning says do not excide 35 mph and ihave a ECu fault on the dash. The air bags were repalced at 80 thousand miles it currentlyhas 122. i am seriously thinking of going to coil overs. It is currently on the bump stops in my garage...im completely frustrated.. can anyone please help?.
Old Jan 3, 2009 | 04:39 PM
ldivine's Avatar
Default RE: air suspesnion
Are you sure it's the bags? They may be in need of replacement again but it is a bit soon... have you sprayed down the bags and around the collet to o-ring connections to check for leaks? Next step would be to verify the compressor is actually working.
For the cost of coils you could just about fix anything wrong with the EAS. But it's a personal choice and i'd just recommend determining what the problem is first.
tripz
Jan 4, 2007 05:58 PM
