brake parts factory or aftermarket
Old Feb 8, 2009 | 10:33 PM
cnterline's Avatar
4wd High
Default brake parts factory or aftermarket
2005 range roverdo I have to use factory rotors and pads or can I use aftermarketwhere there wont be a problem
Old Feb 9, 2009 | 12:47 PM
thelokolobo's Avatar
Default RE: brake parts factory or aftermarket
On a specialized vehicle like the Range Rover, I definitely wouldn't skimp and use aftermarket parts. Just my opinion
Old Feb 9, 2009 | 03:14 PM
luxury1's Avatar
Unless you are doing a major upgrade like Brembo's all the way around I would stay with OEM parts especially for brakes.
Old Feb 9, 2009 | 09:57 PM
handsome rob's Avatar
OEM is great dont get me wrong but aftermarket can be just fine too. I would feel comfortable buying an aftermarket kit from someone like Atlantic British. I would not just run into Autozone and buy the cheap rotors from China. Good luck!
Old Feb 10, 2009 | 06:06 PM
ldivine's Avatar
Seems like rotors are covered well already . For pads though I would personally recommend using EBC GreenStuff but there are also many other pads that are as good, if not better, then the OEM ones (which tend to squeal more then they should).
Regards
Old Feb 15, 2009 | 05:11 PM
darrelljr00's Avatar
aftermarket only.. make sure you get some ceramic pads.. quieter and much less brake dust.. federo rotors are fine.. dont have to be drilled or slotted just regular is fine.. ebc greenstuff are good too.. but spend the extra few bucks and get the ceramic.. We wouldnt want to hear u braking before we see u
HeliRy
Headers, Intake, & Exhaust
Jun 28, 2013 10:38 AM
s10lowrider1994
Dec 29, 2012 07:53 PM
tjhappel
Feb 20, 2011 07:54 PM
roverintherocks
Dec 8, 2010 10:36 AM
