Buying a used Range Rover
Old Dec 6, 2007 | 10:26 AM
jkeving's Avatar
Default Buying a used Range Rover
My son is looking at purchasing a mid-90's Rover and has identified a couple with less than 100k miles that he THINKS he can afford. Any advice on what he should look for or what years are best?
Old Dec 6, 2007 | 10:42 AM
Default RE: Buying a used Range Rover
Great safe truck, very capable , not the best on gas mileage and does need to run on high octane. If he is pretty mechanical, it would be a pretty awsome vehicle.
Old Dec 6, 2007 | 10:53 AM
Roverboy3766's Avatar
im am 16. i love my range rover. i drive a 1996 range rover 4.0 se. i think it it worth it. there is not another car on the road like them. for any situation, a range rover is always appropiate.
Old Dec 7, 2007 | 05:54 PM
sgnden's Avatar
4th Gear
Hello JK...
Here is a great set of information for you. Have fun...but be prepared with some reserve cash for parts and service issues you don't want to handle yourself. These are not you "average" vehicles and certainly not for everyone. Bu I would never part with my '92 Classic County.
http://www.rangerovers.net/rrbuying.htm
Check it out and wait for the right one.
Old Dec 9, 2007 | 04:11 AM
Rainbird's Avatar
3rd Gear
By mid 90's, is he looking at a Classic, or the newer p38?
Apart from the obvious like off road damage....
If he's looking for a Classic, then the main points to look for are corrosion in the front innner wings, rear cross member, sills and rear wheel arches (particularly where the seat belts mount).
Check for water or exhaust gas in the coolant as this can indicate a slipped cylinder liner.
The rear tailgate (based on UK experience) will probably be showing signs of corrosion, but this expected for a 10+ year old vehicle.
High mileage is not a main issue, buy on condition not necessarilly age/mileage as a low mileage vehicle can require more work to put "right" than a well maintained high mileage one. check that all the electric toys work, particularly the air suspension if fitted. If this is knackered, it's very expensive to put right and often cheaper and easier to resort to the original coil spring suspension.
Finally, look at several, take the plunge and enjoy. They do need a bit of fettling, but will tollerate more "issues" than a normal car.
tsam19
Feb 2, 2011 08:02 AM
Moobs
Apr 3, 2010 01:51 AM
Jumpman247
Mar 10, 2006 05:59 PM
gsxlex
Jul 4, 2005 01:02 PM
Mr.S
Jun 10, 2005 06:15 PM
