Changing the bulb in the ATC
Old Jan 11, 2009 | 08:02 PM
ggothlin's Avatar
Default Changing the bulb in the ATC
Ok, I can hardly see the Automatic Temperature Controller, I see that I can buy a new bulb online, but how many do I need and does anyone have the instuctions on how to change these bulbs or bulb?
Thanks if you can help.
Old Jan 15, 2009 | 06:06 PM
skyguy's Avatar
Default RE: Changing the bulb in the ATC
Did you have any luck with this one yet?
Old Jan 15, 2009 | 10:52 PM
ldivine's Avatar
Ok checked RAVE and while I didn't find exact instructions...
Think you need to remove the side panels that go from the centre console down towards the pedals in the footwells. The ATC should be mounted to the centre console. I think you can then remove the front panel to the ATC but i'm not completely sure. You may want to pull the ATC all the way out and see if there isn't another way in. Sorry... haven't done it myself and RAVE doesn't have much on the taking the ATC apart.
Let us know if you pull the panels off what you find out.
Regards
Old Jan 16, 2009 | 08:06 PM
ggothlin's Avatar
Thanks for this info, I am going to see if I can remove the side parts and see what happens.
aftermath431
Oct 15, 2013 06:54 AM
Classklown90
Aug 21, 2010 07:24 PM
mcbenavidez
Nov 24, 2007 05:47 PM
GAZ LUKAS
Oct 24, 2006 05:53 PM
AzCamel
Jun 14, 2005 08:39 PM
