Drive shaft fell out
Old Aug 2, 2008 | 07:43 PM
wess98range's Avatar
8th Gear
Default Drive shaft fell out
1998 Range Rover SE 4.0. As I was driving down the highway my front drive shaft fell outand almost came through the floor board but when it fell out my transmission went into d2. Now when I try to put my car in Park, it is in Reverse and the computer tells me its in reverse and my mirrors go down. So for instance when I have it in Reverse it is really in Neural and when I put it in neutral it is in D3 and ect. Does anyone know how to fix this or will it fix itself once I replace that front drive shaft? And for anyone that lives near the Raleigh, Durham, Chapel hill area do not take your car to the Flying Circus.
Old Aug 2, 2008 | 07:51 PM
8th Gear
Default RE: Drive shaft fell out
Also does anyone know if you can buy the whole assembly of a front drive shaft/propeller with the u-joints and the pieces that attach to the u-joints?
Old Aug 2, 2008 | 08:03 PM
roverguy7's Avatar
it messed up your shift linkage, possible the whole tranny, usually busts the case when this happens, get it checked out
Old Aug 2, 2008 | 10:20 PM
8th Gear
How do I correct the shift linkage?
Old Aug 3, 2008 | 02:26 AM
WolfPack's Avatar
id be more worried about the rest of the tranny honestly...take it to a shop.
Old Aug 3, 2008 | 06:46 AM
Rotorhead1959's Avatar
You better take a good hard look underneath for other damage. Sounds as if you caught the selector and or the linkage. There could also be damage to the trany itself. You may need a shop for this one. Thanks for the tip about the flying circus!!
Old Aug 3, 2008 | 09:38 AM
Your best bet for a new drive shaft is, http://www.4xshaft.com/index.html.
Their drive shaft's are much stronger then Rover and less money, apx. $320.
Old Aug 3, 2008 | 10:12 AM
8th Gear
Thanks for all the advice. Yeah the flying circus actually fixed both of my front u-joints 40k ago, they have fixed a window regulator, and blend motors, which have all broken again. Luckly the window broke within a month so they fixed it for free. With all of this breaking again it makes me believe they are not using new parts. So be careful.
Old Aug 3, 2008 | 11:49 AM
8th Gear
Transmission seems fine, I was able to drive it in 2 wheel drive but of course I did not drive but a few feet so I will have to see once I get the front driveshaft back in. Has anyone used roverland parts? What are your thoughts on their parts?
Old Aug 3, 2008 | 02:30 PM
roverguy7's Avatar
do not drive it without the front dshaft in... youll blow up your viscus in your tbox
