EAS was fixed but rover looks different
i just fixed my EAS fault problem. the mechnic changed my air compressor, vaulve body, and Height control unit. Looks like everything is working properly. but when i looked at my rover my front looked a few inches heigher then it was before. When i look at it from the side you can see the front is heigher then the back. My left back spring sits lower than my right one. any suggested on what happened, or does it sound right.
on
1 Post
I would think the height sensors were knocked but if you didn't have the bags replaced (and just the EAS components under the hood) it shouldn't be the sensors. Sure you aren't just seeing things when you're looking at it? None of those components should have changed the height at all...
Regards
Regards
on
1 Post
Since you took it to a mechanic... i'd say take it back and ask if he possibly might have knocked an EAS height sensor out of place because the suspension height seems out of whack.
Could ask him to swap the sensors (just left and right from front- don't swap front with back) and see if that fixes the problem or just changes where the problem is occurring (in which case you'd need to replace that sensor).
Regards
Regards
Regards
Regards
Re swapping the sensors, usually this will get things settled since the sensor will now be operating on a clean piece of track. (They are just potentiometers)
Chris.
on
1 Post
Technically you're right... changing the bags shouldn't result in sensor faults. However, if the mechanic doesn't work on Rovers you can have a whole host of things go wrong. Sensors would be the first thing I check because it's the easiest fix.
Unless the BECM was changed out... which it wasn't. I wouldn't think it's the BECM. Possibly, the height values in the EAS ECU need to be reprogrammed (shouldn't but it's a last resort fix). And an EAS ECU reset would just clear any faults (none of which were indicated). Correlation does not indicate causation but I would think the EAS problem is, most likely, directly related to the physical work the mechanic performed and not an electrical or mechanical gremlin.
Regards
Regards
Regards
Regards
on
1 Post
What year Rover do you have? Have you replaced the springs or know if they have been replaced? I would crawl under the four corners of the truck and check the condtion of the bags around the base of each bag.
It shouldn't take 10 minutes for the EAS to change heights. It really shouldn't take more then 30-45 seconds tops. Going to the bumpstops is a tell tale sign that something is wrong with the EAS. Continuing to use it will only further compound the problem(s).
Regards
Regards
