eas refit problem
Old Mar 21, 2009 | 07:15 PM
beengel's Avatar
4wd High
Default eas refit problem
I amassed the pieces that I needed to put eas back into my 01 RR. I got the bags back in, reinstalled the compressor and valve block. I have the cable for the eas software, and it works fine.
However, I cannot get the thing to do much. It will not automatically go to the preset heights. the only light on the dash is the lock light, and it is always on regardless of if I hit the switch or not. When I get the faults, it lists a lot of faults....pressure too high, pressure too low...yaddah yaddah yaddah. I think it lists them all.
I disconnected the AB override module thing under the RH seat.
I May have a faulty valve, the RR will not exhaust, and it doesn't click twice like the others when I try to manually bump it up through the software...
Any help would be greatly appreciated.
Old Mar 21, 2009 | 07:45 PM
beengel's Avatar
4wd High
i just got back from running the compressor through software, and I cannot get it to raise the vehicle anymore. It filled the springs a little bit, but nothing now. I can hear the valve clicking, but that's it. It will lower the RR, but that is not what I want now!
and one other thing, the compressor doesn't run unless I make it.
bosshogt
Feb 7, 2011 12:12 AM
riden686
May 8, 2009 04:49 PM
simjack
Oct 12, 2008 10:24 AM
ranger
Sep 26, 2006 06:54 PM
indigenous1
Oct 14, 2005 08:30 PM
