Engine will not go over 2000rpms back fires at intake and bogs.
Old Oct 28, 2010 | 09:09 AM
giboulou13's Avatar
8th Gear
Default Engine will not go over 2000rpms back fires at intake and bogs.
This 1998 4.6 HSE P38,is killing me,just wont go over 2000 rpm.I swapped air mass,coil pack and wires,replace spark plugs,fuel filter,checked fuel pressure 35 psi,separated cats from exh manifolds,checked tp sensor for proper operation found ok.Does any one ever come across this problem before?I,m starting to think may the timing gear stripped some teeths?At idle the engine runs fine upto 2000 rpms than it starts to buck and back fires at the intake manifold any heads-up will help.
Old Oct 31, 2010 | 04:41 PM
booper169's Avatar
i have a similar problem on my 1998 disco 4.0 v8.....anyone?
Old Nov 1, 2010 | 07:37 AM
giboulou13's Avatar
8th Gear
Concernning the P38,I remove the timing cover hopinig to find worned out timing gears but that was'nt the case gears and chain were ok.It's getting more chilly in New York and still no results.
Submariner
Aug 13, 2015 09:22 AM
binvanna
Oct 8, 2012 02:02 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
narleyman63
Feb 2, 2012 09:08 AM
tacomatech
Oct 22, 2008 10:08 PM
