evaporator fans
Old Jun 4, 2007 | 10:02 PM
javarover's Avatar
Default evaporator fans
Hi all, I don't think my evaporator fans are working on my 1999 4.0. Does anyone know how to test them? It's getting hot in Arizona.
Old Jun 5, 2007 | 08:48 AM
Default RE: evaporator fans
Have you checked to see if they are running, do the fans spin freely? You can test them with a test probe to make sure they are getting power, check the fuse and relays. You can also hot wire them to see if they will come on.
They are activated thru the ECU from signals from the high pressure switch on your a.c and also from the engine temp switch.
I wouldn't drive it, much less use your a/c untill you get this resolved, don't want to overheat that engine.
Mike
wardpower
LR2
Jan 30, 2020 11:52 PM
jrm123180
Aug 24, 2019 07:59 AM
pgoodrich
Aug 19, 2015 08:31 PM
Reniam
Freelander
Nov 9, 2006 09:48 PM
SARAH1
Freelander
Oct 30, 2005 12:05 AM
