Fuel injector cleaner?
What's the forums' opinion on adding fuel injector cleaner to the gas tank to help keep the injectors and valves clean? Is there any problem with hurting any seals? I read where my generation truck (1997 Range Rover) tends to accumulate alot of carbon buildup around the exhausr valves. Is Seafoam as good or better alternative?
Thanks
Thanks
Rovers do tend to build up carbon in their cylinders. Additives will help, but not instantly dissolve years of build up. I have used additives on my other vehicles and noticed major improvements. You need to be careful though, using too much might cause a chunk of carbon to break off and clog things up. In the end, the best way to get rid of the junk is to tear down the engine and manually clean the components. I recently did an induction cleaning on my rover and found that it does run better. After the cleaning I took a look at the cylinders through the spark plug hole. I noticed that there was still a considerable amount of carbon build up left... I use seafoam as an induction cleaner, and use MMO (marvel's mystery oil) to clean out the crank case and fuel system. After treating the rover, with the additives it feels and sounds better. Just go light on the additives if you do decide to use them and use them slowly and progressively. I put a little in the oil and fuel before each oil change. Usually 1/4 the "recommended" dosage.
Tony Back
08-21-2014 11:37 PM
DeepBlueWater
10-15-2007 07:38 PM
