Help with mudding
Old May 16, 2006 | 07:40 PM
CJsRover137's Avatar
Default Help with mudding
I have been mudding in my 1990 Range Rover. Why do some of the wheels not spin when I am stuck. It is 4-wheel drive (I actually can't switch it to 2-wheel drive). Also, any advice on off-roading??
Old May 16, 2006 | 08:05 PM
esaycho's Avatar
Default RE: Help with mudding
Is it one front wheel and one rear that spins, it's because we have open differentials. I'm assuming yours does not have traction control to help so getting some lockers or at least a limited slip should help
Old May 16, 2006 | 10:21 PM
All 4wheel drive trucks have only 2 wheels that will spin unless you have lockers, wether it is a J--P or a Toyo.
Some of the new Range Rovers had locking center diffs and sometimes rear diffs which helped put more traction to the ground, depends on the year built.
Mike
Tire Junkie
May 22, 2013 08:09 AM
srockrae
Apr 1, 2013 03:33 PM
honda50r
Appearance & Camping Set Ups
Jan 26, 2012 08:54 AM
skatelove303
May 20, 2009 10:54 PM
