How to change the front air spring with HD photos (2003 -)
I recently changed the front air spring on a Range Rover and wanted to share the procedure with photos for anyone tackling the job. Any questions or comments to improve please share!
Link: Land Rover Help!: How to change the front air strut on your Range Rover (2003 and up)
Ok. The fitting itself is called a Voss fitting. You didn't do anything wrong by removing it and installing it on the air line.
On photos #9 and 10 in your write up you will see there is a white plastic plug in the fitting that is in the strut.
All you need to do is remove the plug, and push the air hose into the fitting, it will push in and lock on the ferrull.
daxter1987
LR2
11-06-2014 03:33 PM
collin Barrows
08-28-2011 08:13 AM
catchthebig1
09-24-2010 12:57 PM
southfloridadiscoII
06-18-2009 09:48 AM
FordCrusherGT
01-10-2007 03:15 PM
