How to change Headlight for Non adaptive headlight. L322
My Rover is US 2008 HSE 4.4L
Tools: Philips screw driver
Time: 10 minutes
1. Remove three screws. (Slide-1)
on outer top ends push down a bit to unclip.
2. Pull the top free a little, and unclip temp sensor attached to inside grille. (Slide-2)
now lift straight up an grille should come free.
3. Remove the three screws from Headlight assemble. (slide-3)
4. Wiggle free a little ways, it is attached by the plug. (slide-4)
5. Unplug, and move to your work bench or tailgate. (slide-5)
6. Open cover, ccw. (slide-6)
7. You can now see the D1S bulb. Twist to remove. Unplug connector. (slide-7)
8. Here are the bulbs I used. (slide-8)
9. Unclip and remove plastic retainer ring. (I left the protective foam cover on the new bulb until I was ready to twist in.) Install the retainer ring on new bulb. (slide-12)(slide-13)(slide-14)
10. Plug wire into new bulb, check orientation, only goes one way. (slide-15)
11. Remove foam cover, insert into housing, then twist.(slide-16)(slide-17)
11. Re assemble in reverse order.
Thanks,
Mitchell.
Time: 10 minutes
Thanks,
Mitchell.
adamsrotors
Sep 28, 2019 12:08 PM
Oasisplayer311
Sep 30, 2017 03:59 PM
megathunder
Sep 26, 2014 09:36 AM
collin Barrows
Aug 28, 2011 07:13 AM
