IAT Testing 1995 2.5 Diesel P38
Old Dec 27, 2017 | 10:01 AM
madbrit's Avatar
4th Gear
Default IAT Testing 1995 2.5 Diesel P38
I am trying to test the IAT (Inlet Air Temperature Sensor) This is the one that sits under the inlet manifold, not the air box.
I have a reading of 12 Ohms with no heat applied (my workshop is at about 5 deg
When I apply a bit of heat with a hot air blower from a distance the ohms do go down quite a bit
What I dont know and cant find out is if 12 ohms is the correct value for it to be at at 5 deg ?
Can anyone point me in the direction of a book or something with bench test data so I know if this is correct
Its a 1995 p38 TD So I understand it is different from the 1996 on P38's
I will also be testing the MAP / Turbo boost sensor but I have no test data to compare it with
Thanks
MB
Speed racer
Oct 29, 2008 12:45 AM
tugumafu
Freelander
Sep 23, 2008 12:28 PM
wielgoshoff
Engine & Internal
Mar 18, 2008 11:37 AM
colby80210
Jan 19, 2007 03:52 PM
kng_kupa
Engine & Internal
Jan 4, 2007 06:13 PM
