just bought a 2000 HSE
RE: just bought a 2000 HSE
If it is locked the pins should do the trick.
You said that it doesn't mount flush or click in right now?
If this is the case. Someone has probably already broken the tabs when pulling it the first time.
With the key on and the radio on try to gently ease it out.
It may just come right out. Mine did and still does.
Again, you MUST have the radio code in case of an accidental disconnect.
The code is a 4 digit number that is unique to your VIN.
If you don't have it and your dealer is cool they will give it to you for free over the phone.
They may ask you to go to the dealer and show proof of ownership.
I also found a website that will sell you the code for $30-$40.
I tested it out and it came up with the same code as the dealer.
rmally
04-22-2008 12:26 AM
