L322 flat battery - now elec problems
Hi all - I have a 2003 4.4 HSE and I left car at the airport for 2 weeks and when I came back the battery was totally flat.Did jump started car and car started easily. Now I have no door locking at all, no front wiper operation, no interior lamps, no lower tailgate operation. Have tested and recharged battery properly. Have inspected all fuses front and rear with testlight. Have had car on Rovacom scanner and there are no faults. Have disconnected battery and left overnight.Scanner can see all signal inputs operatingat BCM but there are no outputs to affected components.Anyone had similar - please let me know - thanks in advance.
on
You need to read your ownersw manual, it will walk you thru the process. Problem with the Range Rovers is there is soooooo much draw on their battery that over two weeks it will kill a battery. I would suggest that if you plan on doing that quite a bit, that you look into a serious battery like a Optium yellow or Blue top or some other top end deep cycle battery that will hold but better.
