largest tire
Old Oct 18, 2012 | 12:22 PM
drowssap's Avatar
Default largest tire
any ideas what is the largest tire I can fit on a stock RRC?
Old Oct 18, 2012 | 12:57 PM
hilltoppersx's Avatar
what kinda suspension? i doubt the air bags are still installed. i have a 2" ome lift and i could get 265/75/16's under it.
Old Oct 19, 2012 | 05:36 AM
drowssap's Avatar
stock coil spring suspension
Old Oct 19, 2012 | 07:11 AM
it must ride like sh*t, no?. measure from the ground to the top of the wheel well on all 4 corners, then measure from the top of the current tyre to the top of the wheel well on all 4. my guess is if they truly are stock and are sagging you're not going to get anything over 31" if you plan on going off road.
Old Oct 19, 2012 | 07:51 AM
drowssap's Avatar
It measures just under 31 inches from the ground to the center of the wheel arch.
Actually with 100k it rides better than a lot of RRC that were converted to springs that I have driven. But I sure most of them were probably converted using some type of off-road spring. I will have to admit a rear sway bar would have been nice.
I have the stock continental 205 80 16 on there now, just looking for options for snow tires.
I believe the 205 80 16 was a Land Rover spec tire, so there aren’t many options in that size.
Old Oct 19, 2012 | 08:56 AM
what happened to the rear sway bar?
I would go with Cooper Discoverer M+S in 235/70/16 or antoher 235/70/16
Old Oct 19, 2012 | 09:19 AM
drowssap's Avatar
Early models did not have a rear sway bar, I believe they were added then are 92-93.
I think that was the same time the eliminated that third rear shock that was used on to self level non-air ride cars.
i will look at 235 70 16 thats a much more normal size, I have alway had good luck with Coopers they alway seem to were quite well.
Thanks
Old Oct 19, 2012 | 11:06 AM
Thanks
you could probably weld a support and used a late model sway. shouldn't be hard. i had to pull my rear sway off when doing my suspension. i should probably replace the bushings in it they were shot.
Old Oct 19, 2012 | 11:23 AM
drowssap's Avatar
I read somewhere that it was offer as a bolt-on from Land Rover for the ealier model.
let me tell you its big difference going from the Disco with ACE to the RRC, some days i might drive both and that first set of twisties is always a surprise you dont know if it going to track like its on rails or try to swing all over the place.
i should probably have Paul pull one for me from one of his parts cars
Old Oct 19, 2012 | 11:27 AM
im waiting on him to get another classic in because i need a driver side door handle.
