leaking transmission fluid
Old Nov 27, 2009 | 06:43 PM
leddifer's Avatar
Default leaking transmission fluid
my 1999 land rover range rover is leaking transmission fluid slighty what should i do?
Old Nov 27, 2009 | 11:01 PM
wease206's Avatar
reseal it
Old Nov 28, 2009 | 01:49 AM
LRScott's Avatar
reseal it
lol
Where exactly is the leak coming from, such as the bell housing, the pan gasket, drain plug etc? Pictures would really help.
Old Nov 28, 2009 | 07:42 AM
wilson96rr's Avatar
You need to crawl under the vehicle and see exactly where it is coming from. Usually where it is dripping from is not where the leak is. Then, when you find it, report back. Having a Land Rover that leaks isn't the end of the world.
Old Nov 28, 2009 | 09:39 PM
krazzz's Avatar
I would be more afraid of the Land Rover that didn't leak. The only time mine don't leak is when they are out of fluid...
Old Nov 29, 2009 | 07:29 AM
leddifer's Avatar
how do i even check the transmission fluid level? becuase i know land rover look out the trans. dipstick on this model. why would they even do that?
Old Nov 29, 2009 | 07:52 AM
wilson96rr's Avatar
Check it cold while at idle I believe. That is how I check mine.
Old Nov 29, 2009 | 08:13 AM
leddifer's Avatar
can you explain to me exactly how to do that? im new to rover but im in love with em.
Old Nov 29, 2009 | 09:05 AM
LRScott's Avatar
You have to take out the fill plug, it should be overflowing a tiny bit. If it is, then the level is correct. Your owners manual might give you more insight on how to do it.
Old Nov 29, 2009 | 09:36 AM
wilson96rr's Avatar
Scott, Isn't there a dipstick? Mine has one. Did LR eliminate them at some point? Just curious.
