My fan blower motor relay keeps blowing? Help!!!
My relay for my A/C & Heating fan blower motor keeps blowing about every 2 weeks. There is a brown burnt mark where the relay inserts. Someone please tell me what to do about this??
Thanks,
Wydell Conley
WydellConley@aol.com
Thanks,
Wydell Conley
on
1 Post
Easiest and quickest way would be replacement of the entire fusebox assembly. Might look for a used one where RL7 isn't damaged.
If you're electrically inclined rangerovers.net has a fairly detailed walkthrough for repairing the circuit board but it appears to be a pretty time consuming job (why I bought a new box).
Regards
Regards
There's 2 relays for the fan blowers under the hood, is only one blowing? Are you actually installing a new one each time? Put a new one in each slot - NAPA carries these for about $24 each. If there's any corrosion around the "burnt" spot try to rub it off with a small wire brush. When this happens, are you getting the "notebook" symbol on your climate control system? Also, there's one fuse if I recall correctly under the passenger seat for the climate control, make sure you have the right one in there, and a good one.
I have to replace one of mine about twice per year - the burnt mark has been there for years.
