My fan blower motor relay keeps blowing? Help!!!
Old Jun 10, 2009 | 04:23 PM
wydell's Avatar
8th Gear
Angry My fan blower motor relay keeps blowing? Help!!!
My relay for my A/C & Heating fan blower motor keeps blowing about every 2 weeks. There is a brown burnt mark where the relay inserts. Someone please tell me what to do about this??
Thanks,
Wydell Conley
WydellConley@aol.com
Old Jun 10, 2009 | 06:13 PM
ldivine's Avatar
Easiest and quickest way would be replacement of the entire fusebox assembly. Might look for a used one where RL7 isn't damaged.
If you're electrically inclined rangerovers.net has a fairly detailed walkthrough for repairing the circuit board but it appears to be a pretty time consuming job (why I bought a new box).
Regards
Old Jun 10, 2009 | 11:10 PM
skyguy's Avatar
before you replace the whole box try a new relay
Old Jun 11, 2009 | 12:40 AM
mlshelton's Avatar
There's 2 relays for the fan blowers under the hood, is only one blowing? Are you actually installing a new one each time? Put a new one in each slot - NAPA carries these for about $24 each. If there's any corrosion around the "burnt" spot try to rub it off with a small wire brush. When this happens, are you getting the "notebook" symbol on your climate control system? Also, there's one fuse if I recall correctly under the passenger seat for the climate control, make sure you have the right one in there, and a good one.
I have to replace one of mine about twice per year - the burnt mark has been there for years.
Cirrus
Oct 21, 2021 09:50 PM
DiscoRover007
Sep 2, 2014 04:49 PM
BigDogg
Jul 4, 2012 09:24 AM
bosshogt
Feb 11, 2011 03:28 PM
okdiscoguy
Nov 15, 2010 04:42 PM
