New 1990 RRC Improving MPG: IDEAS???
Old Apr 6, 2011 | 12:07 PM
Cosmic88's Avatar
Originally Posted by LRScott
Popular Mechanics Did
The following is quoted from the online article you linked me to as published by Popular Mechanics...
"Almost all vehicles show a pulse width of zero when coasting while in gear. Zero, as in there is no fuel injected at all. Yes, the engine is turning over, the pistons are going up and down, the water pump, alternator and a/c compressor are working, so technically you can say the engine is running, sort of. But it's not consuming any fuel. And that goes for automatic or manuals."
That is Absolutely Incorrect! The author has no business sharing his ideas in a manner as to be perceived by others as some sort of Scientific fact proven by a test.
WOW... NO fuel huh? Riddle me this... How is the Engine continuing to turn over with no fuel? Using his example of deceleration on a decline, with no positive actuation of the throttle.
If you say because the transmission is turning the engine as you stated before then I shall simply walk away from this conversation because there would be zero point in continuing.
I'm not picking on you but you gave completely inaccurate information to someone as though it were fact... just because popular mechanics sez so doesn't make it right. IN FACT I can't believe they let something as rediculously misleading as that article be published under their name. Shame on PM.
Old Apr 6, 2011 | 09:50 PM
LRScott's Avatar
Car and Driver also says it.
When Coasting to a Stop, do Not Shift Into Neutral - Feature - Car and Driver
Old Apr 7, 2011 | 10:02 AM
Cosmic88's Avatar
Default Ignorance is MY Bliss
What I do know quite well is the design and function of the Lucas EFI's and a bit less about Gems. This means Disco's pre-99 and RRC's pre-96
I do not claim to know about the intricacies of Current modern EFI's and energy recovery systems like on many Hybrid braking systems. So having said that there may currently be an auto manufacturer out there with a system similar to what has been described in those two articles.
HOWEVER, since we are on the Rover Forum I will stick with Rover systems. And the original queston asked was about a 1990 RRC. At no time during normal operating conditions when the engine is turning and all systems are functioning properly does the 14cux stop supplying a signal to the injectors. As you say in Laymans terms "off" does not occur. Under certain (not all) conditions / gear selections and when the road speed of the vehicle is greater than the power supplied by the engine and greater than the torque required to cause forward motion the torque converter in the ZF (and most all trans.) goes into a state called "overrun" (not in the Diesel sense of the term). This is where the torque converter freewheels and has a reduced control over engine speed. There will be some engine braking but not as much as with a manual trans. For obvious reasons this is different with a R380 which would directly control engine speed since the clutch would be engaged. Again, in this case you will have reduced pulse-width signal to the injector but not a ZERO state.
So, upon deceleration, foot off throttle, tps senses closed throttle and MAF senses lower flow rate, i.e. higher manifold pressure, the ECM goes into idle mode which is not the same as zero pulse signal.
As I said there may be an automaker out there with a system which cuts fuel completely upon deceleration but in our world and for the purposes of this forum that is not the case.
kman3786
Jul 12, 2012 09:14 AM
NebsRover'90
Apr 18, 2011 09:28 PM
tjhawk
Jan 30, 2011 09:16 PM
drhodes
Oct 2, 2009 12:31 PM
bobbysteels
Nov 13, 2007 05:37 PM
