p2119 fault code for 2005 Range Rover
Old Mar 21, 2009 | 11:45 AM
mtate315's Avatar
Default p2119 fault code for 2005 Range Rover
Can someone please help me? I have a 2005 Range Rover and it began jerking and now will not go more than 10 miles and hour. I had it checked and it has a fault code P2119. Does anyone know what this code means.
Old Mar 22, 2009 | 12:14 PM
roverguy7's Avatar
your ecu lost its learned throttle positition. to relearn it, you need to turn the key on, not running, let it sit for 5 seconds, then key off, repeat this. then start it. if that doesnt take care of it, it has to be hooked up to a computer and have the adaptions reset, or there is something wrong with the throttle body itself. try the key cycles first, but you might want to get it checked out, this doesnt happen for no reason. have you had battery issues lately?
Old Mar 24, 2009 | 05:59 AM
mtate315's Avatar
Default P2119 fault code
Yes we have had battery problems. The truck would be fine and then suddenly the battery would die. I would charge it and it would be fine for weeks and then it would die again. We replaced it and there were no more problem except we kept getting a fault code indicitaive of the gas cap not being on tight.
Old Mar 24, 2009 | 08:08 PM
roverguy7's Avatar
did the key on/off fix the reving?? also, these rarely have issues with the evap system, whats causing your p0442 or 455 code. you need to get that checkd out by someone that knows what theyre doing.
Old Aug 2, 2024 | 08:26 PM
E’s2011LR4's Avatar
7th Gear
would love an update on this too, I have the same issue in my 5.0 LR4
angrylobster
Jan 4, 2024 12:40 PM
06Range
May 8, 2013 09:01 PM
sayeedA
Nov 15, 2011 11:02 PM
anhernandez
Aug 18, 2009 12:47 AM
