P38 Lamps Flickering
Old Jan 28, 2006 | 11:00 PM
rangeroverboi's Avatar
Default P38 Lamps Flickering
hey guys,
I have a 97 4.0 SE and I've got a wierd thing going on with the lighting, and electrical system in general. The headlamps, interior lamps, displays, even cooling/heating system fan all "flicker." The climate fan obviously can't flicker; rather it "dolphins" or loops up and down. Engine power seems to be unnaffected, or is minimal. I think I've narrowed it down to a bad voltage regulator, but I wanted to get an opinion from other seasoned pros before I dive into that. The frequency of the flickering generally varies with the RPM of the engine, too. Thanks for your help!
Brett
Old Jan 29, 2006 | 01:18 AM
esaycho's Avatar
Default RE: P38 Lamps Flickering
This happened when I got my Alternator changed, there was a loose wire on the Alternator. Check all your connections, including the ground on the battery.
Old Jan 31, 2006 | 04:52 PM
I think that your suggestion might have worked. I tightened down the alternator and other assorted wires (ie. battery, fuse box). While in the fuse box, I noticed that several of the larger fuses that circumference the fuse box showed signs of burns. I pulled one out, and the plastic board that the fuses plug into was burned, cracked, and brittle. I lightly cleaned the area, uncluding one other fuse that was the same way, and replaced one of the burned fuses with a newer fuse. The flickering seems to have stopped for now, and the Climate Control System works amazing, too. Thanks for the help!
Brett
rambo
Oct 17, 2013 10:13 PM
Bduncan26
Oct 26, 2012 12:48 PM
jmccollister
Sep 23, 2008 05:19 PM
Redmen69
Dec 18, 2004 11:41 AM
