P38 Transmission
Old May 14, 2011 | 07:33 PM
enterusernamehere's Avatar
5th Gear
Default P38 Transmission
OK. so I have a 1996 RR 4.0 SE. None of the gears engage, and it is making a horrible grinding noise. I just did a engine swap on it, and I read somewhere online that I could have done something to the torque converter when I put the engine in. Is that the problem?
Old May 15, 2011 | 06:57 AM
So quit starting it and tow it to a good mechanic, not a dealer. Chances are you have screwed the bush on this one.
Old May 15, 2011 | 06:13 PM
5th Gear
I wouldn't take it to a mechanic because it's cheaper for me to throw in a used one. I just need to know if it's a common problem and it be fixed, or if I just cooked it myself.
Old May 15, 2011 | 08:13 PM
angelis745's Avatar
You'll never know unless you take the tranny apart and take a look at what's going on inside.
Old May 15, 2011 | 10:36 PM
jafir's Avatar
Any chance that the transfer case isn't all the way in high or low? (I know nothing about P38 Ranger Rovers, by the way).
Old May 16, 2011 | 12:32 AM
5th Gear
Good thinking, but no. The scan tool gave me the code P1175 (Gearbox fault).
Old May 17, 2011 | 02:49 AM
LRScott's Avatar
You need to find out where the grinding noise is coming from for us to better assist you.
Old May 17, 2011 | 07:02 PM
Mrmerlin's Avatar
I would guess that the torque convter has slid forwards and disconnected itself from the front pump,
the grinding is the tabs not fully engaged,
bummer bro.
Pull the trans out and remove the torque converter inspect the front pump tabs
peter r
Dec 30, 2022 08:08 AM
Lincoln Tarantino
Jun 26, 2012 11:52 AM
roverdisco1017
Jun 7, 2012 10:13 AM
wannabe
Jan 24, 2011 10:42 AM
pinczehelyi
Jun 23, 2010 12:08 AM
