Range Rover 4.6HSE Cuts out on lpg
Old Dec 16, 2013 | 02:58 PM
bristolrange's Avatar
Default Range Rover 4.6HSE Cuts out on lpg
Hi all!
First proper post on here.
I have a 1995 Range Rover 4.6 HSE with an LPG conversion, had it under a week.
It has been running fine apart from the last couple of days.
The other night the main air intake pipe which also supplies the lpg came off the main block, guessing it had been bodged on with sealent before and the bolts were weak.
I had it bolted back in tight so it wouldnt come off again. But ever since then it cuts out when idling, its fine when its on lpg in park but any other gear, even neutral it just drops below 500rpm and cuts out?
It does have an aftermarket air filter, not sure if that affects it but im going to put it back to standard when i can source one.
It runs sweet as a nut on petrol but like i said cuts out on idle whilst running on gas and sometimes when i accelerate it lacks power and the builds up and kicks back in?
Anyone else experienced this or can give me any advice?
Thanks!
Marc
Paul Grant
14
Nov 5, 2012 05:24 PM
baller
Jun 9, 2011 02:29 AM
medcapequip
Feb 10, 2010 12:54 AM
///Mik3*NW
Apr 18, 2009 02:31 PM
jaspercat10
Mar 21, 2005 08:32 PM
