Range Rover HSE 4.6 not firering......
I have a 97 Range Rover 4.6 and it turns over but will not fire. I get no spark from any spark plug wire. What are the components to check?
It always runs fine, after a broken cooler and wet wirings it no longer runs, he is dead.......................??????
Following message in display: "Left window open, Roof Open, Right open, Engine Blocked" also many messages.
HELP, HELP............[&:]
Thanks for any help, i'm from the Netherlands
RE: Range Rover HSE 4.6 not firering......
First check all of your fuses. If those are all good ,check your crank sensor. This is often the reason for this type of condition. The messages you are getting is because at some point you disconnected the battery. Bring each window up and down (complete cycle) and your messsages should go away.
Oke, first THANKS for the quick answer.
I will try, at first i have to let him regonice the key, because thats a new massage.
I let you know how its gone.
On the passenger drivers side (Eurpean Version) i found a totaly oxcidated connector (green oxcidated water) wich goes to the
Body Electrical Control Mod-ule (BECM), so that thing is to repair first.
cherry
Off Topic
01-05-2009 11:08 PM
AmexBlackG5
06-25-2008 01:04 PM
umoms
04-03-2008 06:22 PM
JimMayor007
12-05-2007 08:46 AM
Stickestar
Appearance & Camping Set Ups
12-13-2006 03:25 AM
